Looking for a Verilog to VHDL converter
djolestojic
Member level 5
Member level 5
verilog2vhdl
Does anybody have verilog to VHDL conversion tool.
Thanks
P.S.
Visit www.opencores.org for free FPGA core codes
the_penetrator
Full Member level 5
Full Member level 5
verilog2vhdl free
Please search for this distribution: verilog2vhdl.tar.Z. Then you have to build it for a Linux/Cygwin (UNIX) target.
If you can't find it, and i still have it, i will upload tomorrow. Actually, it is in the public domain.
the_penetrator©
Laplace
Full Member level 1
acs hdl translator
I have used two kinds of converter, but one of them is good enough as yet. I do not recommend you to use it.
incognito
Member level 2
Member level 2
verilog 2 vhdl translator
well there is 2 main tools
Xtek X-HDL
but I recommend u ACS HDL Translator.. Current version is 5.6,
it is only a bit buggy because the installer forget to add the TMPDIR environment variable
edaguy69
Full Member level 1
silicon land
verilog 2 vhdl
Has anyone try to use Altavista BabelFish translator. Well, it helps us to understand a liitle bit the document but it is not quite right ! Verilog and VHDL have different feature. The tool only translates the syntax not the whole beauty essence of the design. Recommend only for quick solution, designer need to be involved for tune up.
the_penetrator
Full Member level 5
Full Member level 5
verilog2vhdl.tar.z.
Source distribution for the Verilog2VHDL tool.
the_penetrator©
Q
Questa Technologies Suppo
Newbie level 1
Here is a free verilog2vhdl conversion tool which works for all the platform.
You can download it from -
You can contact support@questatechnologies.com for details about this tool.
