looking for a 360 degree tilt switch [crosspost from DIY]
PomPom
Junior Member level 3
I'm looking for a cheap 360 degree tilt switch
Hey there.
I'm looking for a cheap tilt switch to detect if something is knocked over. I'm looking to spend about $2. Digikey/Mouser have very limited options in that price range-- about 3 to be exact.
I want to test a couple different options of tilt angle-- perhaps 25 degrees or 45 degrees.
So I ask you, do you know of any tilt switches other than the two that pop up on digikey and are repeated on mouser? I see plenty for $7+ -- trying to avoid that.
Thanks!
Re: I'm looking for a cheap 360 degree tilt switch
thanks kam.
I'm looking for something repeatable -- to build a hundred of.. perhaps DIY wasn't the right place to post this... :)
i'll x-post to Professional
Hey there.
Thanks!
thanks kam.
Why not go directly to a [major] distributor [or factory].
The sources you mentioned are usually for small orders.
On one B2B website I saw prices for under $1 for volume orders
