Nov 21, 2017 #1 N noisepic Member level 3 Joined Nov 2, 2012 Messages 66 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,781 I'm using IR2104 for fet driver in motor controller, but with that FET I want to use it as constant current sink. Is it another way or I'm looking for the hybrid Fet driver both analog and digital.
Nov 21, 2017 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,161 Helped 4,868 Reputation 9,757 Reaction score 5,537 Trophy points 1,393 Activity points 168,359 Hi, Use IR2104 and PWM to control the current. Klaus
Nov 22, 2017 #3 N noisepic Member level 3 Joined Nov 2, 2012 Messages 66 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,781 I use PWM control the current of LEDs and it flickering. So I look for the hybrid type for precisely control the gate of Fet driver.
Nov 22, 2017 #4 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,161 Helped 4,868 Reputation 9,757 Reaction score 5,537 Trophy points 1,393 Activity points 168,359 Hi, Post#1: motor controller Post#3: LED flickering ??? Klaus
Nov 22, 2017 #5 N noisepic Member level 3 Joined Nov 2, 2012 Messages 66 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,781 Due to some reason, I'd like to reuse motor driver circuit (H) to control LEDs. So I look for the hybrid type Fet driver. Is it clear?
Nov 22, 2017 #6 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,409 Helped 14,749 Reputation 29,780 Reaction score 14,095 Trophy points 1,393 Location Bochum, Germany Activity points 298,048 Your intention is roughly clear, but the prerequisites and possible solutions aren't. First it's not understandable why you get flicker with LED pwm control. Everybody uses is without flicker, if properly designed. Secondly, constant current control needs a current measurement means (e.g. shunt) and a feedback controller. Gate driver is probably a lesser problem.
