I was wondering if anyone knows if local mesh refinement is supported in HFSS.
I have a structure that includes some 90 degree bends and taper sections to which I would like to apply a local mesh refinement routine. Nevertheless I dont want the rest of the mesh to be refined at the same time. I just want the mesh at these regions to be finer with a transition to the coarser mesh at the rest of the structure.
If anyone knows how could I do this in HFSS I would appreciate your comments.
What I do when I want local meshing is insert a vacuum object into that region (or whatever your background material is), and then assign a "seed mesh" to this object. You can specify maximum number of tetrahedra, or minimum edge length.
If I understand you correctly, you are suggesting to assign an "additional vacuum object" (i.e a cube) to the region of interest where I would like to have my mesh refined ? (this region has already assigned material properties different from vacuum)
