I have seen load regulation expressed in several different
ways. V/V, %/V, etc. Some LDOs are incapable of getting
to zero sourced current and a no load - full load test will
give a really poor result while 10%-100% load will look OK.
You need to evaluate test conditions / methods along with
the circuit and the end application(s), to be sure you are
working against realistic expectations and requirements
(these two may or may not be the same, again you need
to understand both).
