natmag
Newbie level 5
- Joined
- Mar 6, 2014
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 75
I am trying to use the LM8272 Op-amp which is a high output current and unlimited capacitive load Op-amp to drive a 2 LM224 Op-amps and 3 analogue switches, AS1745. The LM8272 is used as a unity gain buffer whose output is used as the supply of the afore mentioned components. When the LM8272 is not connected to the rest of the circuitry it is seen to operate correctly and behave like a unity gain buffer. However, on connecting the rest of the circuitry to the output of the buffer, the LM8272 no longer behaves as a unity gain buffer but a voltage drop of 1.3V develops between the positive, negative and output terminals of the op-amp I've tried adding a series resistor between the output of the LM8272 and the rest of circuitry but to no avail .A voltage drop equal to 2V develops. (For resistor values Ive tried 1Ohm, 51Ohms, 100Ohms, 10kOhms.)
I think the components are somehow loading the LM8272 on connection. How can this be mitigated please help .
https://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=lm8272&fileType=pdf .
