Jack.Straw
Member level 2
- Joined
- Apr 9, 2008
- Messages
- 47
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,792
Hello. I've been building fun little LM386 amplifiers. They are powered by 6x AA NiMH rechargeable batteries, with an internal MAX713 IC charging circuit built in. Recently I decided i wanted to add bluetooth capability. I found some inexpensive options on ebay and have ordered a couple different ones. Both options are powered by 5 volts USB, but one of them has a built-in rechargeable battery so that it doesn't have to be plugged in all the time. Here is an overview of how I was thinking of implementing the bluetooth add-on:
The two bluetooth modules i have already ordered are:
And finally, my questions:
1) The LM7805 says it requires 7 volts input. I know my 6x AA rechargeables only supply 7.2 volts fully charged... what happens as the batteries start to loose charge?
2) Which bluetooth option would conserve overall battery life? I feel like the battery powered option might be it, but then we enter into a batteries charging batteries situation, which I know nothing about. Currently the 6x AA batteries last a really long time powering the amplifier alone. How much impact do you think the bluetooth will have on battery life? I could add a separate on/off switch for the bluetooth option, but would really prefer it to share the amplifer's on/off switch since i think i will be using the bluetooth option a majority of the time.
Thanks in advance for any advice you can offer!
-Scott
-Scott
