[PIC] lm35 intercacing to pic18f4550
vgavale
Newbie level 2
Newbie level 2
the code is running but it is not displaying temperature value.
following is code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
/*This program demonstrates the interfacing of LCD to PIC18F4550 microcontroller*/
LCD DATA port----PORT D
signal port------PORT E
    rs-------RE0
    rw-------RE1
    en-------RE2
#include <p18f4550.h>
#include<stdlib.h>
//LCD data pins connected to PORTD and control pins connected to PORTE
#define LCD_DATA    PORTD               //LCD data port
#define ctrl        PORTE               //LCD signal port
#define en          PORTEbits.RE2      // enable signal
#define rw          PORTEbits.RE1      // read/write signal
#define rs          PORTEbits.RE0     // register select signal
#define BUSY        PORTDbits.RD7
#define Channel0 0b00000000
#define Channel1 0b00000100
void ADC_Init();
void Select_Channel(unsigned char Channel);
void Get_ADC_Result(void);
void Start_Conversion(void);
void myMsDelay (unsigned int time);
//LCD function definitions
void LCD_Busy(void);
void LCD_cmd(unsigned char cmd);
void init_LCD(void);
void LCD_write(unsigned char data);
void LCD_write_string( char *str);
//void LCD_itoa(unsigned float t,arr[5])
/*The following lines of code perform interrupt vector relocation to work with the USB bootloader. These must be
used with every application program to run as a USB application.*/
extern void _startup (void);
#pragma code _RESET_INTERRUPT_VECTOR = 0x1000
void _reset (void)
        _asm goto _startup _endasm
#pragma code
#pragma code _HIGH_INTERRUPT_VECTOR = 0x1008
void high_ISR (void)
#pragma code
#pragma code _LOW_INTERRUPT_VECTOR = 0x1018
void low_ISR (void)
#pragma code
//Function to generate delay
        unsigned int i, j;
        for (i = 0; i < time; i++)
                for (j = 0; j < 710; j++);/*Calibrated for a 1 ms delay in MPLAB*/
// Function to initialise the LCD
void init_LCD(void)
    LCD_cmd(0x38);      // initialization of 16X2 LCD in 8bit mode
    myMsDelay(15);
    LCD_cmd(0x01);      // clear LCD
    myMsDelay(15);
    LCD_cmd(0x0C);      // cursor off
    myMsDelay(15);
    LCD_cmd(0x80);      // ---8 go to first line and --0 is for 0th position
    myMsDelay(15);
//Function to pass command to the LCD
    LCD_DATA = cmd;
    rs = 0;
    rw = 0;
    en = 1;
    myMsDelay(15);
    en = 0;
    myMsDelay(15);
    return;
//Function to write data to the LCD
    LCD_DATA = data;
    rs = 1;
    rw = 0;
    en = 1;
    myMsDelay(15);
    en = 0;
    myMsDelay(15);
    return ;
//Function to split the string into individual characters and call the LCD_write function
void LCD_write_string( char *str)   //store address value of the string in pointer *str
    int i = 0;
    while (str[i] != 0)
        LCD_write(str[i]);      // sending data on LCD byte by byte
        myMsDelay(15);
                i++;
    return;
void ADC_Init()
 ADCON0=0b00000000; //A/D Module is OFF no channel selected
 ADCON1=0b00001110; // Reference as VDD & VSS, AN0 set as analog pins
 ADCON2=0b10001110; // Result is right Justified
                    //Acquisition Time 2TAD
                    //ADC Clk FOSC/64
 ADCON0bits.ADON=1; //Turn ON ADC module
 ADCON0=ADCON0 & 0b11000001;
 ADCON0=ADCON0 | Channel;   //selecting channel no 0
void Start_Conversion()
 ADCON0bits.GO=1;
//If you do not wish to use adc conversion interrupt you can use this
//to do conversion manually. It assumes conversion format is right adjusted
void Get_ADC_Result()
unsigned float t;
char arr[5];
unsigned char val,pot0[6];
 unsigned int ADC_Result=0;
 while(ADCON0bits.GO);
 ADC_Result=ADRESL;
 ADC_Result|=((unsigned int)ADRESH) << 8;
 t=(ADRESH * 0.48876); //Convert to Degree Celcius - ADRES (16bit) is the output of ADC
 void main(void)
    unsigned float t;
unsigned int adc_val;
unsigned  char arr[5];
     char var1[] = "Temperature:";
     ADCON1 = 0x0F;        //Configuring the PORTE pins as digital I/O
     TRISD = 0x00;         //Configuring PORTD as output
     TRISE = 0x00;         //Configuring PORTE as output
    init_LCD();           // initialization of LCD
     myMsDelay(5);       // delay of 5 mili seconds
    LCD_write_string(var1);
Get_ADC_Result();
 LCD_cmd(0xC0);
 LCD_write_string('itoa(t,arr[5])');
LCD_write(0xDF);
* * * * LCD_write('C');
while(1)
Select_Channel(Channel0);
Start_Conversion();
 Get_ADC_Result();
   //LCD_cmd(0xC0);
 //LCD_write_string(var1);
 // Move cursor to line 2 position 1
** * //*LCD_write('t'); * * * * *// Display the temperature*
* * * *// LCD_write(0xDF);
* * * //* LCD_write('C');
