lm35 and micrcontroller
nalawade
Junior Member level 2
If i interface lm35 with ADC0804 and
ADC with 'X' micro controller.
what should be the code for putting those ADC values " 8 bit " inside the micro controller memory.
And later I want to send those ADC values to the RF Transmitter using SPI or USart.
So how do I achieve this ? How to write a code for that?
Basically I want to transmit continuous values of temperature sensor to ADC 0804
send those values to RF receiver and from there to another micro controller
Please help in detail . M doing it for the first time
This depends on a lot of different things. What microcontroller, type of memory, addressing mode, compiler, etc... The XC8 and HTC compilers have some built in functions for internal eeprom writing that would work. After your go/done flag is cleared, set the eeprom address to write to and write the ADC register to that spot of memory. If you wanted to store multiple items without overwriting, you would have to keep track of the addresses you have used with a counter and increment the current address after each write phase.
