I am using LM338T as voltage regulator for my college project. I desire an output voltage of 3.5V. The datasheets available for LM338T say that its pin configuration is (ADJ OUT IN) when looking from the front side i.e from the side where the name is readable. But on connecting it that way, no regulated output is obtained. The output just keeps fluctuating as the input voltage is increased. Can you please give me the correct configuration, which gives the required voltage output. Also please clarify if different manufacturers have different pin configurations for the same IC.
Eagerly awaiting your reply.
Thanks a lot.
AMIT.
