LM 350 Power supply for high current.
sn_burki
Full Member level 5
Pakistan
Hi all,
I want to make a variable power supply based on LM 350 5A by using any power transistor in combination, I want short circiut protectoin in my power supply if any one has any schematic or project plz help me.
regards
Hi all, I want to make a variable power supply based on LM 350 5A by using any power transistor in combination, I want short circiut protectoin in my power supply if any one has any schematic or project plz help me. regards
Yes..as stated By malik, the said device is capable of 3A. Instead as you intend to use a transistor, you may use it effectively to boost the current. You may use LM317 To220 package, in conjunction with a 2N2955 PNP transistor TO3 package or MJ4502 to get 5 amps current. regarding application circuit you may refer to the LM317 datasheet.
