ballimo
Member level 3
Dear All,
I have 4 Crystal oscillators with a supply voltage of 3.3V; the output frequencies of these oscillator is : 155 MHz, 311 MHz , 644 MHz, 100 MHz.
I have used a Linear Regulator to supply the 3.3V for these oscillators; My question is:
should I use a ferrite bead for each VDD pin (supply voltage pin) of these oscillator? the linear regulator has a very low noise output voltage, so I guess a filtering is not needed, but do we need an isolation using a ferrite bead?
Thanks in advance,
Ballimo
Thanks in advance,
Ballimo
