Line FIlter Design : AC mains
saumya_85
INDIA
I need to design a filter circuit for the below points :
I need to avoid any signal or noise for the below two frequency range 60 ~ 90KHz and 110 ~ 135 KHz ( or 150 KHZ)
AC mains : 90~300V AC / 2A
Could anybody help me out for the same or may suggest how to design the filter circuits ...
FvM
Super Moderator
Staff member
Bochum, Germany
A filter has finite stop band suppression. Instead of saying "avoid any signal", you need to define an attenuation.
The filter will be usually a LC low pass filter. For an exact design, the load impedance should be known.
darla1
Full Member level 3
India
yes
please decide the following b4 design
1. Power level of your converter
2. Choose best possible capacitor(Y type b/w line to ground and neutral to ground
3. Choose the crossover frequency
then
Find
1/root(LC)=wn
wn=2*pi*f
then find geta=Lwn/2RL (RL is load resistance)
thanks
