Library not found error message + VCS
dpaul
Advanced Member level 5
Germany
I have a Xilinx VHDL IP which I am compiling along with other Verilog and SV design files. I am compiling the VHDL design files first.
Prior to compiling the VHDL design files, I have compiled the Xilinx VHDL libs using the command:
compxlib -s vcs -p /home/shared/Synopsys/I-2014.03-SP1/bin/ -arch spartan6 -dir /home/dpaul/rtl_work/xilinx_vhdl_libs -l vhdl -lib all -log /home/dpaul/rtl_work/xilinx_vhdl_libs_compile.log
In the vhdlan command I also using the switch -smart_order
Still I am getting the following error:
Error-[OVNOSELECT1_LIB] Undefined identifier
/home/dpaul/rev28462_fpga/src/top_modules/axi_iic_v1_02_a/proc_common_v3_00_a/srl_fifo_rbu2_f.vhd, 256
IMP
        DYNSHREG_F_I : entity proc_common_v3_00_a.dynshreg2_f
  The symbol named 'DYNSHREG2_F' cannot be found in library   'PROC_COMMON_V3_00_A'.
I have cross checked that logical and physical lib mapping for PROC_COMMON_V3_00_A exists in the synopsys_sim.setup file.
Not only this I am also compiling the dynshreg2_f.vhd file before compiling srl_fifo_rbu2_f.vhd.
Here's part of the code where the error occurs:
library ieee;
use     ieee.std_logic_1164.all;
use     ieee.numeric_std.UNSIGNED;
use     ieee.numeric_std.">=";
use     ieee.numeric_std.TO_UNSIGNED;
library proc_common_v3_00_a;
use     proc_common_v3_00_a.proc_common_pkg.clog2;
entity srl_fifo_rbu2_f is
  generic (
// generics
  port (
   // ports
end entity srl_fifo_rbu2_f;
architecture imp of srl_fifo_rbu2_f is
begin
    -- The dynamic shift register that holds the FIFO elements.
    DYNSHREG_F_I : entity proc_common_v3_00_a.dynshreg2_f   <-- ERROR HERE!
        generic map (
            C_DEPTH   => C_DEPTH,
            C_DWIDTH  => C_DWIDTH,
            C_FAMILY  => C_FAMILY
        port map (
            Clk   => Clk,
            Clken => FIFO_Write,
            Addr  => addr_i(ADDR_BITS-1 downto 0),
            Din   => Data_In,
            Dout  => Data_Out
What could I do here?
