[SOLVED] Library compiler and design compiler
amitk3553
Full Member level 1
DELHI, INDIA
Hello All
In Logic synthesis, as we use Design compiler(DC).
But for conversion of logic library from .lib to .db, we need library compiler(LC).
So I want to confirm that LC is present in DC because we don't use any LC additionally, we just use DC????
Thanks with Regards
Amit Kumar
I don't know whether they require two license.
But in ordinary, we just invoke the Design Compiler and type the following commands to convert .lib to .db
dc_shell> read_lib io_wc.lib
dc_shell> write_lib wccom -f db -o io_wc.db
Best Regards,
PoLo
Best Regards,
PoLo
Thanks for reply
Ya thats right we perform the read,write steps as above. But I just want to know where is Library Compiler.Is it in DC????
Thanks for reply
you can invoke your Design Compiler and check on the tool list shown on the top.
The tool list may includes HDL Compiler, DFT Compiler and so on.
In my case, Library Compiler (TM) is also included when I invoke the Design Compiler.
But I have never invoke the library compiler alone with other commands.
My point what is the need / importance of converting the .lib format to .db?
If you want to apply Design Compile for synthesis, the library format is .db instead of .lib
They are the same and can be converted.
Generally, the usage depends on other EDA tool.
Does that mean that DC does not read / parse / understand .lib or is a limitation to use .db only. In this case I would be curious why?
its related to DC compatibility, DC is made only compatible with .db files in internal sharing means for internal operation format is binary i.e. .db, it can take input in VHDL, .lib etc. and can output in .sv, .svhd, .edf, but whole internal operation happens in .db.
Hmm.. thanks i was really not aware that DC is unable to parse the standard construct support file .lib
