googler123
Junior Member level 1
I am using the Design Compile to convert XXX.lib 2 XXX.db.
But there are many warnings ,,here is it..
Warning: Line 211468, Cell 'XOR3X4', pin 'Y', The 'values' attribute has a '-0.089602' value,
which is less than '0.000000' the minimum recommended value of this attribute. (LBDB-272)
Warning: Line 211468, Cell 'XOR3X4', pin 'Y', The 'values' attribute has a '-0.032635' value,
Warning: Line 211574, Cell 'XOR3X4', pin 'Y', The 'values' attribute has a '-0.045365' value,
Warning: Line 211656, Cell 'XOR3X4', pin 'Y', The 'values' attribute has a '-0.003312' value,
And as we known,the XX.lib file must has not that values.
So,Why it has negative values?? and The tools changed some values in which I want to know How the tools calculate out them?
Could you give some information?
Thanks a lot.
Thanks a lot.
