buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 960
- Helped
- 40
- Reputation
- 82
- Reaction score
- 24
- Trophy points
- 1,298
- Location
- Florida, USA
- Activity points
- 9,116
Hi
I have a model vehicle that takes a 12v FM1212 brick sealed-lead-acid battery with F1-terminal contact.
Is there a Li-ion replacement available in the same form factor?
If the voltage is slightly different than it is not a problem, for example 10V-16V would be OK.
My problem is that when I am not using the model for 3 months or more, the battery dies and needs replacement, the max chargeability reduces to zero Ah. Probably a Li-ion or Li-polymer or even a Ni-Mh battery would last a lot longer than 3months.
