Several European universities have agreements with LFoundry; as a member of them you may get a design and layout course, and - against signing an NDA - access to an LFoundry C@dence Virtuoso PDK for design & layout of an MPW project.
Here the connections for your MOS transistor. The Gate can be accessed from both sides.
Here the connections for your MOS transistor. The Gate can be accessed from both sides. View attachment 150907
Not sure this is correct. Assuming this is a simple mos device then the connections are S/D(gate) on left or right, GATE(Drain) on top, body(Source) on bottom.
