Length Rule Altium Designer
Andreas2010
Newbie level 2
can I create in Altium Designer a rule like this Length rule in the pdf-File, please search it am1808.pdf with google because it's not allowed for me to post links, on page 119 No.1
under the table 6-36 there is a note:
CKB0B1 is the sum of the length of the CK net plus the average length of the DQS0 and DQS1 nets.
I don't know if it's possible because in the PCB Rules and Constraints there are only the two rules i know like Length and Matched Net Length Rules.
Thanks and Regards,
Andreas
Anonymous_Ricky
Advanced Member level 2
India
It is possible but you have to really try out on DRC settings.
I think using adnvanced query option in Altium you can define the particular setting.
Andreas2010
Newbie level 2
I think the only problem I have to figure out how I can form the sum. Does anyone have a syntax proposal.
Thanks and Regards,
Andreas
Anonymous_Ricky
India
i think help document named "Tuning Route Lengths" could help you in setting up the rule.
Also you can go through this thread
"https://www.edaboard.com/threads/160114/"
zula
Full Member level 2
Turkey
i think you can do it with 'query helper'. check these pdfs; AR0129, TR0116 and 'TR0110'.
