LEM current transducer does not give any output
sprooch
Junior Member level 1
Nederland
lem current transducer
I need help fpr my project.
I am using a current transducer from LEM (HXS 20-NP, datasheet attached) for measuring current.
I have 3 components, and my problem is that all the components did not show any output when I changed the current. So, what I am thinking is that the test circuit I made was wrong.
Anyone know what the connection should be?
the connection I made is attached
how to connect lem current transducer
Are you sure the input & output direction are correct? It looks like you might have these reversed. Then again I might need more coffee...zzzzzzzz
regards
dfullmer
what does a current transducer do?
mmm...
sorry I drew it the wrong way. The connection here is right (I attached the correct drawing).
when I measured the output voltage, it showed 7.34mV. I increased the current and the output voltage keep increasing...7.35mV, 7.36mV and never stops at one value.
design of a current transducer
sprooch said:
mmm...
you are using 20A configuration & which current value you want to measure. also whitch type of current I mean AC or DC
lem current sensor voltage output
7 mV related to VRef or GND? The latter would mean saturation, output voltage is measured differentially to Vref.
lem has current transducers problem
so whats the input voltage and is it DC or AC?
input voltage: 5V DC
I want to measure 0 - 15 A
Vout to Ground
Is the Vref pin in the component an input or output?
What I understand , the Vref is an input, so I put 2.5V there.
I have doubt on my understanding. Maybe it is an output. What do you think?
lem current transducer connection
Hi
I think it is an output. But with 5 volts across a 2K resistor you will never hit the current you are looking for. 5/2000 = 2.5 milliamps.
Do I understand you correctly?
dfullmer
reading data sheet of current transducers
The datasheet is clear in this respect. Vref is IN/OUT with 200 ohms internal impedance. You can either connect it to a load (> 200 k) or supply it from a low impedance external source, when needed. The permissible voltage range is 2.0 to 2.8 V then. Vout must be near to Vref without sensor current. 7 mV referred to ground is out of range. Can't say why, from a distance.
lem transducer
Hey, guys...
I have solved the problem...
The problem was the connection on my PCB...
1 should be the input (1st pin) and 8 will be the output (last pin)..
I connected them wrong....
my mistake on reading the datasheet picture..
thanks for your help...
