led tube parellel/series connection
maxim10373
Dear All
I need to make an LED Tube light in five feet long,
I bought 60 nos 5050 SMD LED.so which is the sutable
connection is parellel or series ?How many LED can connect
in a parellel circuit 12 v dc and which resistor should use their?
I think to connect 60 nos LED in one row.
LED details;
smd led 5050
for.volt=3.6
for current=300ma
input v=12 or ?
Please reply
maxim
you can use 12vdc 20A power supply
and you need to connect 3LED's series.
if you using 24vDC 10A power supply,
and you could go with 6Led's series..
if you use 3 LEDs in series, volt drop = 3 X 3.6 = 10.8 V, Vsupply = 12, Volts to loose = 12 - 10.8 = 1.2V, therefore series resistor = 1.2/.3 = 4.0 ohms, so 20 chains @ .3A each, is a 20 X .3 = 12V, 6 A PSU. For 24V PSU, 6 LEDs in each chain, so 2.4 V to loose at .3 A = 8 ohms, so PSU for 10 chains = 24 V @ 3A.
Frank
sir,
There havn't more space for put a big powersupply.
can I connect this 220v series
Thanks
maxim
If you connect all 60 in series these will take 60 X 3.6 = 216 Volts at .3 A. But you have AC, so you need a bridge rectifier, to turn the AC into DC. and you need a 230-216 = 14Volts to loose at a current of .3A = 14/.3 = 47 ohm resistor which will dissipate .3 X14 ~ 5W.
BEWARE THIS STUFF IS DANGEROUS!!!!
Frank
