led driver to detect 10Mhz signal
jaggu5360
Newbie level 3
Newbie level 3
can anyone help me to design a circuit, which glows led when it detects 10Mhz lvds differential signal.
note: once it detects the signal led should on.(i mean to say that it should nt be on and off). if there is no signal, then led should off.
LVDS to single ended into some sort of peak detector could work , IF there are no other signals on the line.
Hi jaggu5360
Many ways are lie a head !
one of the simplest ones is using a filter for 10 MHZ and then a peak detector or a comparison network based on a simple op amp !
Best Wishes
Goldsmith
