infini8zx
Newbie level 2
Hi all.
I am working on LED dot matrix produce by Sure Electronic which the board uses Holtek chip (HT1632). Does anyone know on how to develop program for this chip? Currently I am using PIC16F877A. I am not very familiar with PIC. I search for information on the net and most of them recommend SPI module.
Here is the code so far. I just want to light up any of the LED on the board. But it seems not working. I dont know whether the clock aint connect properly or due to program itself.
Any hint or help will be much be appreciated. Thanks in advance.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 unsigned char i; char test[30] = "Hello world! World of hello." ; void main() { // SPI_init(); // standard configuration CMCON = 0x07; // Disable comparators ADCON1 = 0x0F; // Disable Analog functions // instead of SPI_init, you can use SPI_init_Advanced as shown below // SPI_init_Advanced(Master_OSC_div64, Data_SAMPLE_MIDDLE , CLK_Idle_HIGH , HIGH_2_LOW); TRISC &= 0xFD; // max7219_init1(); // initialize max7219 //while (1){ Spi_Init_Advanced(MASTER_OSC_DIV64, DATA_SAMPLE_MIDDLE, CLK_IDLE_HIGH, HIGH_2_LOW); PORTC &= 0xFD; PORTC.f1 = 1; PORTC.f1 = 0; SPI_write(0b00000100); // Delay_ms(2); SPI_write(0b00000000); //sys dis // Delay_ms(2); SPI_write(0b00000100); // Delay_ms(2); SPI_write(0b00100000); //com option // Delay_ms(2); SPI_write(0b00000100); // Delay_ms(2); SPI_write(0b00011100); //master mode // Delay_ms(2); SPI_write(0b00000100); // Delay_ms(2); SPI_write(0b00000001); //sys on // Delay_ms(2); SPI_write(0b00000100); // Delay_ms(2); SPI_write(0b00000011); //led on // Delay_ms(2); PORTC.f1 = 1; Delay_ms(2); PORTC.f1 = 0; SPI_write(0x02); // Delay_ms(2); SPI_write(0x80); // Delay_ms(2); SPI_write(0xFF); Delay_ms(1000); PORTC.f1 = 1; }~!
