neazoi
Advanced Member level 6
Hello, in case A on the attachment the LED is completely switched off when 0v is applied on ACC. But in case B, when 0v is applied on ACC, the led is not completely switched off but it is very dim. I measured the voltage on the transistor base when off and this was 0.6v as expected. Then I measured the voltage across an off LED and it was about 2.6v. On 3v LEDs this 2.6v means a very dim LED (I have used high efficiency blue LEDs). Does the transistor still conducts some electrons even when 0.6v on it's base? I have not a clue. It is ok but I would like to solve why this is happening.
