vitruvius
Newbie level 5
Hi all. I'm a begginer at VHDL and Fpga and i have Spartan-3E Starter Kit. I tried to do led control with using only one button. I wanted that when i press the button, next led will be logic 1. The problem is; leds don't be logic 1 in the right order.
My Vhdl Code:
Thank you for your answers.
My Vhdl Code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity btn_state_de is
Port ( btn : in STD_LOGIC;
clk : in STD_LOGIC;
rst : in STD_LOGIC;
led : out STD_LOGIC_VECTOR (7 downto 0));
end btn_state_de;
architecture Behavioral of btn_state_de is
type state_type is (s0,s1,s2,s3,s4,s5,s6,s7,s8);
signal state : state_type;
begin
process (clk,rst)
begin
if (rst='1') then
state <= s0;
elsif (clk'event and clk='1') then
case state is
when s0 =>
if btn='1' then
state <= s1;
else
state <= s0;
end if;
when s1 =>
if btn='1' then
state <= s2;
else
state <= s1;
end if;
when s2 =>
if btn='1' then
state <= s3;
else
state <= s2;
end if;
when s3 =>
if btn='1' then
state <= s4;
else
state <= s3;
end if;
when s4 =>
if btn='1' then
state <= s5;
else
state <= s4;
end if;
when s5 =>
if btn='1' then
state <= s6;
else
state <= s5;
end if;
when s6 =>
if btn='1' then
state <= s7;
else
state <= s6;
end if;
when s7 =>
if btn='1' then
state <= s8;
else
state <= s7;
end if;
when s8 =>
if btn='1' then
state <= s0;
else
state <= s8;
end if;
end case;
end if;
end process;
process (state)
begin
case state is
when s0 =>led<="00000000";
when s1 =>led<="10000000";
when s2 =>led<="01000000";
when s3 =>led<="00100000";
when s4 =>led<="00010000";
when s5 =>led<="00001000";
when s6 =>led<="00000100";
when s7 =>led<="00000010";
when s8 =>led<="00000001";
end case;
end process;
end Behavioral;
