LED blinking program
jidan12
Newbie level 5
Newbie level 5
HI,
I wrote code for LED blinking
start
turn ON LED
wait for some time (delay )
turn OFF LED
// LED blinking c code
//start
//turn ON LED
// wait for some time (delay )
// turn OFF LED
include<regx51.h>		        // header file for 8051
include<delay.h>				// header file for delay
#define LED_ON  00000001		// LED ON
#define LED_off 00000000        // LED OFF
void main()					   //main function starts
while (1)				       //infinite loop
setb P1_1=00000001;
delay (1000);
setb P1_1=00000000;
"LED" - 0 Error(s), 2 Warning(s).
this code with no error
this code will work ?
That won't work because after executing the code
setb P1_1=00000000;
the instruction pointer jumps immediately to
setb P1_1=00000001;
to turn the LED on again. With common microcontroller clock frequencies this means the duty cycle of the LED will be very close to 1, thus giving the impression the LED is turned on all the time. You need to add a second delay after turning the LED off.
Also, why are you defining the constants LED_ON and LED_OFF, while you don't use them?
//start
//turn ON LED
// turn OFF LED
setb P1_1=00000001;
delay (1000);
setb P1_1=00000000;
[COLOR="#FF0000"]delay (1000);[/COLOR]
What is the LED state after programmed your original program?
