Leakage power reduction
kumar_eee
Advanced Member level 3
Bangalore,India
What are all the methods you use during the leakage power optimization other than Vt swapping?
phoenixpavan
Full Member level 4
Bangalore
Hi Kumar,
we can perform the following methods for Power opt
Supply voltage reduction
clock gating(dynamic power reduction)
Multi Vt
Mutivoltage design(using level shifter cells)
Power switching(using isolation cells and retention registers)
DVFS(dynamic voltage and frequency scaling)
cheers,
kumar_eee
Bangalore,India
Hi Pavan, Thanks a lot. I'm specifically looking for the leakage power optimization methods.
divya ravi
Newbie level 2
chicago
Methods for leakage power optimization are
1. Reducing Threshold Voltage(Vt)
2. source biasing
3. body biasing
dineshrayar
Newbie level 3
hi..
if u reducing Vt means.. the leakage power will increase.. so if u want to reduce leakage power u have to go for high Vt cells or MTCMOS, variable Vt CMOS, multi VDD design or power gating methods.. basically in high freq design dynamic power dissipation will be more n leakage will be less... there will be lot of tradeoffs b/w leakage/dynamic power, freq and no of Vdd's....
kumar_eee
Bangalore,India
presently I use HVT cells to reduce the leakage power. Does std cell library contains the MTCMOS cells also?
