tahir4awan
Full Member level 4
Hi guys I am usig MikroC Compiler with PIC16F887 microcontroller. I have written a program to move text left and right. The text is moving left and right but the problem is when text moves left the moved part of the text comes from right.
See the picture below,
I want the text moves towards left completely so that LCD become blank then text moves in.But as you can see in the picture when text moves left it comes in from right. Note that it happens for both left and right but I am only giving left move example.
The program is,
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char txt1[] = "mikroElektronika";
char txt2[] = "EasyPIC6";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i; // Loop variable
void Move_Delay() { // Function used for text moving
Delay_ms(500); // You can change the moving speed here
void main(){
ANSEL = 0; // Configure AN pins as digital I/O
ANSELH = 0;
C1ON_bit = 0; // Disable comparators
C2ON_bit = 0;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,6,txt3); // Write text in first row
Lcd_Out(2,6,txt4); // Write text in second row
Delay_ms(1000);
Lcd_Out(1,1,txt1); // Write text in first row
Lcd_Out(2,5,txt2); // Write text in second row
Delay_ms(1000);
// Moving text
while(1) { // Endless loop
for(i=0; i<13; i++) { // Move text to the left 7 times
Lcd_Cmd(_LCD_SHIFT_LEFT);
Move_Delay();
for(i=0; i<13; i++) { // Move text to the right 7 times
Lcd_Cmd(_LCD_SHIFT_RIGHT);
Move_Delay();
Any idea
![](https://obrazki.elektroda.pl/69_1305418598_thumb.gif)
![](https://obrazki.elektroda.pl/68_1305418598_thumb.gif)
The program is,
void main(){
ANSELH = 0;
C2ON_bit = 0;
Delay_ms(1000);
Delay_ms(1000);
// Moving text
Move_Delay();
Move_Delay();
Any idea
