kasamiko
Full Member level 3
- Joined
- May 23, 2004
- Messages
- 154
- Helped
- 16
- Reputation
- 32
- Reaction score
- 18
- Trophy points
- 1,298
- Location
- Philippines
- Activity points
- 1,121
Hello guys..need a little help here..
I construct a project for solar lighting using PIC16F877A, it will simply monitor battery and solar voltage via ADC and switch on/off load and charge a battery.
Now ADC was set to 5V, now my problem is if the battery or solar voltage is low or the ADC goes below 5V like 3V, my LCD goes BLANK. :-(
I am attaching the code and and my Proteus file.
CODE:
Any help will be appreciated..
WBR
CODE:
#include <pic.h>
#include <math.h>
#include "lcd.h"
#define charge_Batt_1_Solar 0x15
#define charge_Batt_2_Solar 0x0E
#define Batt_Low_Solar 0x07
#define charge_over 0x08
#define charge_Batt_1_AC 0x11
#define charge_Batt_2_AC 0x0A
#define Batt_Low_AC 0x03
void delay(unsigned int time) // Delay
unsigned int i, j;
for(i=0;i<time;i++)
for(j=0;j<time;j++);
void ADC_Init() // Intialise ADC
ADCON0 = 0x01;
ADCON1 = 0xC4; //Right justified,AN0,AN1,AN3 are analog input.
ADRESH = 0;
ADRESL = 0;
unsigned int ADC_Read(unsigned char channel)
ADCON0 &= 0xC7; //Clearing the Channel Selection Bits
ADCON0 |= channel<<3; //Setting the required Bits
delay(10); //Acquisition time to charge hold capacitor
ADGO = 1; //Initializes A/D Conversion
while(ADGO == 1); //Wait for A/D Conversion to complete
return (256 * ADRESH + ADRESL); //Returns Result
void main(void)
{ unsigned int Solar,Batt_1,Batt_2,temp,unit,a,b,c,d,x,y,z;
TRISA = 0x0F; //
TRISB = 0x00; // port B as output
TRISC = 0x00; // port C as output
TRISD = 0x00; // port D as output
lcdint(); // intialised LCD
cmm(0x01); // clear display
cmm(0x80); // 1'st line of LCD
data_str(" SMART CHARGER ");
cmm(0xC0); // 2'nd line of LCD
data_str(" Version 1.0 ");
delay(300);
ADC_Init(); // Initialise ADC
while(1)
Solar = ADC_Read(0);
unit = Solar; // Temperature is conveted to ASCII
if(unit > 900)
{ Batt_1 = ADC_Read(1);
Batt_2 = ADC_Read(3);
if((Batt_1 < 650)&&(Batt_2 > 850))
cmm(0x80); // 2nd line of LCD
data_str("BATT-1 CHARGING");
cmm(0xC0); // 2nd line of LCD
data_str("BATT-2 FULL SOL.");
PORTC = charge_Batt_1_Solar;
delay(100);
if((Batt_2 < 650)&&(Batt_1 > 850))
data_str("BATT-2 CHARGING");
data_str("BATT-1 FULL SOL.");
PORTC = charge_Batt_2_Solar;
delay(100);
if((Batt_1 > 850)&&(Batt_2 > 850))
data_str("BATT-2 FULL");
data_str("BATT-1 FULL");
PORTC = charge_over;
delay(100);
if((Batt_1 < 650)&&(Batt_2 < 650))
cmm(0x80); // 1st line of LCD
data_str("BATT-1 BATT-2");
data_str("CHARGING SOL.");
PORTC = Batt_Low_Solar;
delay(100);
else
data_str("BATT-2 FULL AC");
PORTC = charge_Batt_1_AC;
delay(100);
data_str("BATT-1 FULL AC");
PORTC = charge_Batt_2_AC;
delay(100);
if((Batt_1 > 650)&&(Batt_2 > 850))
delay(100);
data_str("CHARGING AC");
PORTC = Batt_Low_AC;
delay(100);
WBR
