dheerajc
Hello all,
I have written a code in verilog for interfacing of 16x2 LCD with Numato Uno Spartan 6 FPGA board. Clock is 100 Mhz. However LCD is not even getting initialized. Can someone please tell me what is wrong with the logic.
And this is the constraint file.
module my_lcd(
input clk,
output reg rs,en,rw,
output reg [7:4] LCD_out
reg[7:0] count=0;
reg [24:0] i=0;
reg [7:0] char_data;
reg [7:0] j;
reg [24:0] num =0;
reg [3:0] lcd_data;
initial begin
/* LCD Power ON Initialization time >15ms */
rs=0;
en=0;
rw=0;
Delay(2000000); //20 ms delay
end
always@(posedge clk)begin
//if(count==10)count=0;
case(count)
0 : begin
LCD_Command (8'h28); /* Initialization of 16X2 LCD in 4bit mode */
// char_data = (8'h0F & 8'h28);
// LCD_out = /*(LCD_out & 8'h0F) |*/ (char_data << 4);
count <= count + 1'b1;
end
1 : begin
LCD_Command (8'h01); //clear display screen
//char_data = (8'h0F & 8'h01);
//LCD_out = (char_data << 4);
end
2 : begin
LCD_Command (8'h02); //Return home
//char_data = (8'h0F & 8'h02);
end
3 : begin
LCD_Command (8'h0E); //Display ON cursor blinking
//char_data = (8'h0F & 8'h0E);
end
4 : begin
LCD_Command (8'h0F); //Display ON cursor blinking
end
5 : begin
LCD_Data(8'h48); //'H'
//char_data = (8'h0F & 8'h0F);
end
6 : begin
LCD_Command (8'h14); //Display ON cursor blinking
end
7 : begin
LCD_Data(8'h45); //'E'
end
8 : begin
end
9 : begin
LCD_Data(8'h4C); //'L'
end
10 : begin
end
11 : begin
end
12 : begin
end
13 : begin
end
14 : begin
end
15 : begin
LCD_Data(8'h4F); //'O'
end
16 : begin
count <= 1'b1;
end
default : LCD_Data(8'h48); //By default display 'H'
endcase
end
task LCD_Command (input [7:0] j);
begin
rs=0; /* Command reg. */
Delay(100000); //1 ms delay
rw=0;
Delay(100000);
//LCD_out = (LCD_out & 8'h0F) |(j & 8'h0F);//(LCD_out & 8'h0F) |(j & 8'hF0);/* Send upper nibble */
LCD_out = ( j & 8'hF0);
/* Write operation */
en=1;
Delay(500000);
en=0;
Delay(500000);
LCD_out = /*(LCD_out & 8'h0F) |*/ (8'hF0)&(j << 4);/* Send lower nibble */
en=1; /* Enable pulse */
Delay(500000);
en=0;
Delay(500000);
end
endtask
task LCD_Data (input [7:0] char_data);
begin
rs=1; /*Data reg.*/
Delay(100000);
rw=0; /*Write operation*/
Delay(100000);
//LCD_out = (LCD_out & 8'h0F) | (char_data & 8'h0F);//(LCD_out & 8'h0F) | (char_data & 8'hF0);/* Send upper nibble */
LCD_out = ( char_data & 8'hF0);
en=1'b1;
Delay(500000); //5 ms delay
en=1'b0;
LCD_out = /*(LCD_out & 8'h0F) |*/ (8'hF0)&(char_data << 4);/* Send lower nibble */
en=1'b1; /* Enable pulse */
en=1'b0;
end
endtask
task Delay (input [24:0] i);
begin
if(num == i) num =0;
else num = num + 1;
end
endtask
endmodule
NET "clk" LOC = V10; //100 Mhz clock
NET "rs" LOC = R10 | IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 3 //P8
NET "en" LOC = R11 | IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 1 //P8
NET "rw" LOC = U13 | IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 5 //P8
//NET "LCD_out[0]" LOC = H17 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 1 //P9
//NET "LCD_out[1]" LOC = J16 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 3 //P9
//NET "LCD_out[2]" LOC = K15 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 5 //P9
//NET "LCD_out[3]" LOC = L15 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 7 //P9
NET "LCD_out[4]" LOC = L15 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 1 //P9
NET "LCD_out[5]" LOC = K15 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 3 //P9
NET "LCD_out[6]" LOC = J16 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 5 //P9
NET "LCD_out[7]" LOC = H17 ; //| IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST ; #Pin 7 //P9
