Lcd for bit data sending through a 8 bit port
gravity123
Junior Member level 1
Hello friends ,
I want to send an 4 bit data to LCD along with the enable and RS data through the same port of an 8 bit controller.
that is the Data is 4 bit consider my data is "C'
controllerport = ((c >> 4) & 0x0f) | EN | RS;
is it correct ?
or how can i send the EN and RS data without affect the c data.
Hello friends ,
is it correct ?
Hoped, this will help you
This codes for PIC 16F877a MCU using HI_TECH C compiler and HD44780 compatible LCD
In your case you did not mention MCU and compiler which are using
#define LCD_EN RB3
#define    LCD_RS RB5
#define    LCD_RW RB4
#define LCD_DATA    PORTD
#define    LCD_STROBE()    ((LCD_EN = 1),(LCD_EN=0)
4 bit mode sending data to LCD
void lcddata(unsigned char value)
LCD_RS = 1;
LCD_DATA= ((val>>4)&0x0F);
LCD_STROBE;
LCD_DATA =(val&0x0F);
LCD_STROBE;
__delay_ms(10);
8 bit mode sending data to LCD
LCD_DATA = value;
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 1;
__delay_ms (1);
LCD_EN = 0;
View attachment lcd 4bit.rar
#include <REGX51.H>
#include <stdio.H>
#define LCDPORT P2
sbit RS = LCDPORT ^ 4;
sbit EN = LCDPORT ^ 5;
void delay(unsigned int msec)
int i, j;
for (i = 0; i < msec; i++)
for (j = 0; j < 1275; j++);
void LCDSTROBE(void)
EN = 1;
    delay(4);
EN = 0;
void dt(unsigned char c)
RS = 1;
delay(50);
LCDPORT = ((c >> 4) & 0x0f);
LCDSTROBE();
    LCDPORT = (c & 0x0F) ;
LCDSTROBE();
void cmd(unsigned char c)
RS = 0;
delay(50);
    LCDSTROBE();
LCDPORT = (c  & 0x0F);
LCDSTROBE();
void lcdclear(void)
cmd(0x01);
delay(2);
void lcd_init()
delay(15);
    cmd(0x38);
delay(1);
cmd(0x38);
delay(100);
cmd(0x38);
    cmd(0x28);			// Function set (4-bit interface, 2 lines, 5*7Pixels)
	delay(1);
cmd(0x0c);			// Make cursorinvisible
lcdclear();			// Clear screen
cmd(0x6);			// Set entry Mode(auto increment of cursor)
void string(const char *q)
while (*q) {
	dt(*q++);
main()
delay(50);
lcd_init();
LCDPORT = 0x00;
 while (1) {
cmd(0x80);
string("HELLO WORLD");
cmd(0xc0);
string("IT IS WORKING:-)");
This is the my code but it is not working what is the problem .
Am using 8051 with keil
attached full projects with proteus
