Muhammad Faran
i am using lcd jhd 162A and using microcontroller AT89c51
lcd only shows black boxes in the second line...
dont know whats the problem is it initialization problem or something else in coding???
plz plz help
CODE:
plz plz help
CODE:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 #include<reg51.h> #define port2 P2 sbit rs = P1^0; sbit rw = P1^1; sbit e = P1^2; //DELAY FUNCTION void delay(unsigned int msec) { int i,j ; for(i=0;i<msec;i++) for(j=0;j<1275;j++); } // LCD COMMAND SENDING FUNCTION void lcd_cmd(unsigned char item) { port2 = item; rs= 0; rw=0; e=1; delay(1); e=0; return; } // LCD DATA SENDING FUNCTION void lcd_data(unsigned char item) { port2 = item; rs= 1; rw=0; e=1; delay(1); e=0; return; } // LCD STRING SENDING FUNCTION void lcd_string(unsigned char *str) { int i=0; while(str[i]!='\0') { lcd_data(str[i]); i++; delay(10); } return; } void main() { lcd_cmd(0x38); //2 LINE, 5X7 MATRIX lcd_cmd(0x0e); //DISPLAY ON, CURSOR BLINKING lcd_string(unsigned char “working”); } }
