LCD display with pic16f877a
john120
Banned
Hello every body,I am trying otinterface my lcd to pic16f877a but as this is the first time I am not coming to the right solution.
could you please help me to solve the issue.
I am using CCS C COMPILER OR MPLAB with assembly language.
Thanks
I am using 16*1 Lcd display with pic16f877a ,I want to display "hello" in full screen.
The codes in assembly and ccs c are welcome.
My simulation in Proteus has been added here.
This should get you going, plenty of tutorials on lcds if you search this forum.
  • LCD877A.7z
I want to display " Hello" alone and then display " World"after the first cleared and so on meanwhile displaying a world at a time and in using only one line not 2 lines mode.
Thanks!!
The code is a complete simple demo of displaying to the most common 16 x 2 display -sure you can work out how to use it with just one line...
hi if you have not find solution i can help you. tell me!!!
#include <16f877.h>
#fuses xt, nowdt, noprotect, noput
#use delay (clock = 4000000)
#include "lcd.c“ // include this lcd driver
void main()
lcd_init(); // initialize the lcd module
lcd_putc(“HELLO WORLD \n"); // prints HELLO WORLD in 1st line and returns the cursor to 2nd line lcd_putc(“world "); // prints world in 2nd line
Yes,thanks for your reply,how can I display the resukt of an ADC reading after displaying those lines??
for example after displaying "World" use a button then the pic reads the adc and display its result on the screen.
Thanks!!
you need to use ADC of the pic and you must create a functions to do that....
The code shows how to convert your adc result using an Ascii converter subroutine.
However the ascii converter I have only converts a 8 bits / one byte value into a 3 ascii digits.
For a full 10bit adc result you will need to search for an ascii converter than will accept 10/16 bits and produce at least 4 digits of ascii output or display the adc result as a series of ten x ones and zeros
  • 877lcd.7z
hi friend,
how to write adc program with out using library function
can somebody help me with the codes for getting adc on the lcd using ccs c compiler?
Thanks!!
You have to save the adc result in an int variable and then convert the int or float value to string and display it on lcd.[/QUOTENormally,I know how to do ADC and display for example on seven segment but now I want to display on LCD see the code below for example on seven segment display it on LCD:
#include<16f877a.h>
#device ADC = 10 // Need to tell compiler ADC is configured for 10-bit reading
#fuses HS,NOWDT
#use delay(clock=20000000)
#include<stdio.h>
#include<STDLIB.H>
#use standard_io(A)
#use standard_io(B)
#use standard_io(D)
#define PORTB
#DEFINE PORTC
#define PORTA
byte const digit[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
char display[2];
int value;
unsigned long volt;
unsigned int value2;
void main(){
set_tris_A(0xFF);
set_tris_B(0X00);
set_tris_D(0x00);
output_b(0);
output_d(0);
setup_comparator(NC_NC_NC_NC);
setup_adc(ADC_CLOCK_INTERNAL);
setup_adc_ports(AN0);
set_adc_channel(0);
setup_vref(FALSE);
while(TRUE){
delay_us(100);
//value=read_adc(); //Not required
read_adc(ADC_START_ONLY);
delay_us(100);
value=read_adc(ADC_READ_ONLY);
volt=(value*500)/1023; //I changed this part of the code
value2=volt;
output_low(PIN_D1);
display[0]=value2/10;
output_high(PIN_D0);
output_B(digit[display[0]]);
delay_ms(10);
output_low(PIN_D0);
display[1]=value2%10;
output_high(PIN_D1);
output_B(digit[display[1]]);
delay_ms(10);
Thanks
#include <16f877a.h>
#device ADC=10
#use delay(clock=4000000)
#Fuses HS,NOWDT,NOPROTECT,PUT,NOLVP
#use rs 232(baud=4800,xmit=PIN_C6)
#bit LED=5.5
#include <lcd.c>
void main()
float temperature;
float temp;
float value;
float volt;
setup_adc_ports( ALL_ANALOG );
setup_adc(ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
value = read_adc();
volt = (value / 1023) * 5;
temp = volt * 100;
lcd_init();
set_tris_a(0x1F);
//set_tris_d(0b11110111);
set_tris_b(0xff);
set_tris_c(0xff);
delay_ms(5);
lcd_gotoxy(1,1);
printf(lcd_putc "\fHow");
delay_ms(1500);
printf(lcd_putc "\fis it ");
delay_ms(1500);
printf(lcd_putc "\ffor ");
delay_ms(1500);
printf(lcd_putc "\fyou");
delay_ms(1500);
printf(lcd_putc "\fall?");
delay_ms(5000);
//printf(lcd_putc "temperature:%3.2f\f",temp);
printf(lcd_putc,"Temp is:%f",temp);
see the exercice I am doing but the last line is not printing the temperature on the lcd,what is the syntax for that?
Help me plz!!
