LCD Display Code using VHDL
Kingdom_Walker
Newbie level 1
Newbie level 1
Hi, I am a second year electrical engineer student doing a project on multimeter. I have been trying to get the LCD display to display the mode the multimeter is in. I found a code online called LCD_Controller to initialize the LCD display. However, whenever I reset, the display does not come back up again. Can you please take a look at my codes and tell me what's wrong? Thank you!
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY lcd_example IS
  PORT(
      clk       : IN  STD_LOGIC;  --system clock
      mode		: IN  STD_LOGIC_VECTOR(1 DOWNTO 0); -- Select Between Voltmeter,Ammeter,Ohometa and Beta
      reset		: IN  STD_LOGIC;  --Active Low
      rw, rs, e : OUT STD_LOGIC;  --read/write, setup/data, and enable for lcd
      lcd_data  : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); --data signals for lcd
END lcd_example;
ARCHITECTURE behavior OF lcd_example IS
  SIGNAL   lcd_enable : STD_LOGIC;
  SIGNAL   lcd_bus    : STD_LOGIC_VECTOR(9 DOWNTO 0);
  SIGNAL   lcd_busy   : STD_LOGIC;
  COMPONENT lcd_controller IS
    PORT(
       reset_n    : IN  STD_LOGIC; --active low reinitializes lcd
       lcd_enable : IN  STD_LOGIC; --latches data into lcd controller
       lcd_bus    : IN  STD_LOGIC_VECTOR(9 DOWNTO 0); --data and control signals
       busy       : OUT STD_LOGIC; --lcd controller busy/idle feedback
  END COMPONENT;
BEGIN
  --instantiate the lcd controller
  dut: lcd_controller
    PORT MAP(clk => clk, reset_n => reset, lcd_enable => lcd_enable, lcd_bus => lcd_bus,
             busy => lcd_busy, rw => rw, rs => rs, e => e, lcd_data => lcd_data);
  PROCESS(clk)
    VARIABLE char  :  INTEGER RANGE 0 TO 10 := 0;
  BEGIN
    if(clk'EVENT AND clk = '1') THEN
      IF(lcd_busy = '0' AND lcd_enable = '0') THEN
        lcd_enable <= '1';
			IF(mode="00")THEN --Voltmeter
                IF(char < 10) THEN
				char := char + 1;
				END IF;
				CASE char IS
					WHEN 1 => lcd_bus <= "1001010110"; --V
					WHEN 2 => lcd_bus <= "1001101111"; --o
					WHEN 3 => lcd_bus <= "1001101100"; --l
					WHEN 4 => lcd_bus <= "1001110100"; --t
					WHEN 5 => lcd_bus <= "1001101101"; --m
					WHEN 6 => lcd_bus <= "1001100101"; --e
					WHEN 7 => lcd_bus <= "1001110100"; --t
					WHEN 8 => lcd_bus <= "1001100101"; --e
					WHEN 9 => lcd_bus <= "1001110010"; --r
					WHEN OTHERS => lcd_enable <= '0';
				END CASE;
			ELSIF(mode="01") THEN --Ammeter
                IF(char < 10) THEN
				char := char + 1;
				END IF;
				CASE char IS
					WHEN 1 => lcd_bus <= "1001000001"; --A
					WHEN 2 => lcd_bus <= "1001101101"; --m
					WHEN 3 => lcd_bus <= "1001101101"; --m
					WHEN 4 => lcd_bus <= "1001100101"; --e
					WHEN 5 => lcd_bus <= "1001110100"; --t
					WHEN 7 => lcd_bus <= "1001110010"; --r
				END CASE;
			ELSIF(mode="10") THEN --Ohmmeter
				IF(char < 10) THEN
				char := char + 1;
				END IF;
				CASE char IS
					WHEN 1 => lcd_bus <= "1001001111"; --O
					WHEN 2 => lcd_bus <= "1001101000"; --h
					WHEN 4 => lcd_bus <= "1001101101"; --m
					WHEN 5 => lcd_bus <= "1001100101"; --e
					WHEN 6 => lcd_bus <= "1001110100"; --t
					WHEN 7 => lcd_bus <= "1001100101"; --e
					WHEN 8 => lcd_bus <= "1001110010"; --r
				END CASE;
			ELSIF(mode="11") THEN --Beta"meter
			    IF(char < 10) THEN
				char := char + 1;
				END IF;
				CASE char IS
					WHEN 1 => lcd_bus <= "1001000001"; --B
					WHEN 2 => lcd_bus <= "1001100101"; --e
					WHEN 3 => lcd_bus <= "1001110100"; --t
					WHEN 4 => lcd_bus <= "1001100001"; --a
				END CASE;
			END IF;
      ELSE
        lcd_enable <= '0';
      END IF;
    END IF;
  END PROCESS;
END behavior;
--   FileName:         lcd_controller.vhd
--   Dependencies:     none
--   Design Software:  Quartus II 32-bit Version 11.1 Build 173 SJ Full Version
--   HDL CODE IS PROVIDED "AS IS."  DIGI-KEY EXPRESSLY DISCLAIMS ANY
--   WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
--   LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
--   PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL DIGI-KEY
--   BE LIABLE FOR ANY INCIDENTAL, SPECIAL, INDIRECT OR CONSEQUENTIAL
--   DAMAGES, LOST PROFITS OR LOST DATA, HARM TO YOUR EQUIPMENT, COST OF
--   PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY OR SERVICES, ANY CLAIMS
--   BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF),
--   ANY CLAIMS FOR INDEMNITY OR CONTRIBUTION, OR OTHER SIMILAR COSTS.
--   Version History
--   Version 1.0 6/2/2006 Scott Larson
--     Initial Public Release
--    Version 2.0 6/13/2012 Scott Larson
--   CLOCK FREQUENCY: to change system clock frequency, change Line 65gfdg
--   LCD INITIALIZATION SETTINGS: to change, comment/uncomment lines:
--   Function Set
--      2-line mode, display on             Line 93    lcd_data <= "00111100";
--      1-line mode, display on             Line 94    lcd_data <= "00110100";
--      1-line mode, display off            Line 95    lcd_data <= "00110000";
--      2-line mode, display off            Line 96    lcd_data <= "00111000";
--   Display ON/OFF
--      display on, cursor off, blink off   Line 104   lcd_data <= "00001100";
--      display on, cursor off, blink on    Line 105   lcd_data <= "00001101";
--      display on, cursor on, blink off    Line 106   lcd_data <= "00001110";
--      display on, cursor on, blink on     Line 107   lcd_data <= "00001111";
--      display off, cursor off, blink off  Line 108   lcd_data <= "00001000";
--      display off, cursor off, blink on   Line 109   lcd_data <= "00001001";
--      display off, cursor on, blink off   Line 110   lcd_data <= "00001010";
--      display off, cursor on, blink on    Line 111   lcd_data <= "00001011";
--   Entry Mode Set
--      increment mode, entire shift off    Line 127   lcd_data <= "00000110";
--      increment mode, entire shift on     Line 128   lcd_data <= "00000111";
--      decrement mode, entire shift off    Line 129   lcd_data <= "00000100";
--      decrement mode, entire shift on     Line 130   lcd_data <= "00000101";
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY lcd_controller IS
  PORT(
    busy       : OUT   STD_LOGIC := '1';  --lcd controller busy/idle feedback
END lcd_controller;
ARCHITECTURE controller OF lcd_controller IS
  TYPE CONTROL IS(power_up, initialize, ready, send);
  SIGNAL    state      : CONTROL;
  CONSTANT  freq       : INTEGER := 50; --system clock frequency in MHz
BEGIN
  PROCESS(clk)
    VARIABLE clk_count : INTEGER := 0; --event counter for timing
  BEGIN
  IF(clk'EVENT and clk = '1') THEN
      CASE state IS
        --wait 50 ms to ensure Vdd has risen and required LCD wait is met
        WHEN power_up =>
          busy <= '1';
          IF(clk_count < (50000 * freq)) THEN    --wait 50 ms
            clk_count := clk_count + 1;
            state <= power_up;
          ELSE                                   --power-up complete
            clk_count := 0;
            rs <= '0';
            rw <= '0';
            state <= initialize;
          END IF;
        --cycle through initialization sequence
        WHEN initialize =>
          busy <= '1';
          IF(clk_count < (10 * freq)) THEN       --function set
            --lcd_data <= "00111100";      --2-line mode, display on
            lcd_data <= "00110100";    --1-line mode, display on
            --lcd_data <= "00110000";    --1-line mdoe, display off
            --lcd_data <= "00111000";    --2-line mode, display off
            e <= '1';
          ELSIF(clk_count < (60 * freq)) THEN    --wait 50 us
            lcd_data <= "00000000";
            e <= '0';
          ELSIF(clk_count < (70 * freq)) THEN    --display on/off control
            lcd_data <= "00001100";      --display on, cursor off, blink off
            --lcd_data <= "00001101";    --display on, cursor off, blink on
            --lcd_data <= "00001110";    --display on, cursor on, blink off
            --lcd_data <= "00001111";    --display on, cursor on, blink on
            --lcd_data <= "00001000";    --display off, cursor off, blink off
            --lcd_data <= "00001001";    --display off, cursor off, blink on
            --lcd_data <= "00001010";    --display off, cursor on, blink off
            --lcd_data <= "00001011";    --display off, cursor on, blink on
            e <= '1';
          ELSIF(clk_count < (120 * freq)) THEN   --wait 50 us
            e <= '0';
          ELSIF(clk_count < (130 * freq)) THEN   --display clear
            lcd_data <= "00000001";
            e <= '1';
          ELSIF(clk_count < (2130 * freq)) THEN  --wait 2 ms
            e <= '0';
          ELSIF(clk_count < (2140 * freq)) THEN  --entry mode set
            lcd_data <= "00000110";      --increment mode, entire shift off
            --lcd_data <= "00000111";    --increment mode, entire shift on
            --lcd_data <= "00000100";    --decrement mode, entire shift off
            --lcd_data <= "00000101";    --decrement mode, entire shift on
            e <= '1';
          ELSIF(clk_count < (2200 * freq)) THEN  --wait 60 us
            e <= '0';
          ELSE                                   --initialization complete
            clk_count := 0;
            busy <= '0';
            state <= ready;
          END IF;
        --wait for the enable signal and then latch in the instruction
        WHEN ready =>
          IF(lcd_enable = '1') THEN
            busy <= '1';
            rs <= lcd_bus(9);
            rw <= lcd_bus(8);
            lcd_data <= lcd_bus(7 DOWNTO 0);
            clk_count := 0;
            state <= send;
          ELSE
            busy <= '0';
            rs <= '0';
            rw <= '0';
            clk_count := 0;
            state <= ready;
          END IF;
        --send instruction to lcd
        WHEN send =>
        busy <= '1';
        IF(clk_count < (50 * freq)) THEN  --do not exit for 50us
           busy <= '1';
           IF(clk_count < freq) THEN      --negative enable
            e <= '0';
           ELSIF(clk_count < (14 * freq)) THEN  --positive enable half-cycle
            e <= '1';
           ELSIF(clk_count < (27 * freq)) THEN  --negative enable half-cycle
            e <= '0';
           END IF;
           state <= send;
        ELSE
          clk_count := 0;
          state <= ready;
        END IF;
      END CASE;
      --reset
      IF(reset_n = '0') THEN
          state <= power_up;
      END IF;
    END IF;
  END PROCESS;
END controller;
Hello,
I'm having the same problem....
I'm trying to change de word shown in the displays but everything i tried didn't work.
Could you make it work?
LaTeX Commands Quick-Menu:
