adnan012
Advanced Member level 1
HI
i want to interface PIC24F16KA102 AND LCM-S01602DTR M.
The code runs on proteus simulation but not on hardware.
i want to use port b for 8 bit data and control pins. what is the correct way of writing data and control signals on same 16 bit port.
////////////////////////////////main.c//////////////////////////////////////
#include <24F16KA102.h>
#include <stdio.h>
#include <lcd.h>
#FUSES WPOSTS1, frc , NOBROWNOUT
#use delay(clock=1000000)
//#use rs232(UART2,baud=1200,parity=N,bits=8)
//#use rs232(baud=1200, xmit=PIN_b0,rcv=PIN_b1)
void WriteCommandToLCD(unsigned char);
void WriteDataToLCD(char);
void InitLCD(void);
void ClearLCDScreen(void);
//void WriteStringToLCD(const char*);
char k= 0x00;
void main()
InitLCD(); // Initialize LCD in 8bit mode
ClearLCDScreen();
while(1)
//delay_ms(100);
ClearLCDScreen();
delay_ms(100);
WriteDataToLCD('t');
WriteDataToLCD('e');
WriteDataToLCD('m');
WriteDataToLCD('p');
WriteDataToLCD('=');
WriteDataToLCD(k);
delay_ms(500);
//////////////////////lcd.h///////////////////
// Define Pins
#bit LCD_E = 0x02CA.7 // Enable pin for LCD
#bit LCD_RS = 0x02CA.6 // RS pin for LCD
//#byte PORTB = 0x02CA // Data bus bit 4
#byte TRISB = 0x02C8
#byte LATB = 0x02CC
#byte ODCB = 0x02CE
// Define Pins direction registrers
#bit LCD_E_Dir = 0x02C8.7
#bit LCD_RS_Dir = 0x02C8.6
#bit LCD_RS_d0 = 0x02C8.10
#bit LCD_RS_d1 = 0x02C8.10
#bit LCD_RS_d2 = 0x02C8.10
#bit LCD_RS_d3 = 0x02C8.11
#bit LCD_RS_d4 = 0x02C8.12
#bit LCD_RS_d5 = 0x02C8.13
#bit LCD_RS_d6 = 0x02C8.14
#bit LCD_RS_d7 = 0x02C8.15
#byte PORT_B_L=getenv("SFR
ORTB")
#byte PORT_B_H=PORT_B_L+1
unsigned char data;
//long long data;
int16 test;
//int8 addr = 0x33;
//int8 data = 0x22;
void ToggleEpinOfLCD(void)
output_bit (PIN_B7 , 1); // Give a pulse on E pin
delay_us(500); // so that LCD can latch the
output_bit (PIN_B7 , 0); // data from data bus
delay_us(500);
void WriteCommandToLCD(unsigned char Command)
int temp =command;
output_bit (PIN_B6 , 0); // It is a command
temp=(temp<<8);
output_b(temp );
ToggleEpinOfLCD();
void WriteDataToLCD(char LCDChar)
int temp =LCDChar;
output_bit (PIN_B6 , 1);
temp=(temp<<8);
output_b(temp | 0x40); // making output_bit (PIN_B6 , 1);
ToggleEpinOfLCD();
void InitLCD(void)
output_bit (PIN_B6 , 0); // E = 0
output_bit (PIN_B7 , 0); // D = 0
output_b(0x0000);
///////////////// Reset process from datasheet //////////////
delay_ms(40);
WriteCommandToLCD(0x30);
delay_ms(6);
delay_us(300);
delay_ms(2);
WriteCommandToLCD(0x38); //function set
WriteCommandToLCD(0x0c); //display on,cursor off,blink off
WriteCommandToLCD(0x01); //clear display
WriteCommandToLCD(0x06); //entry mode, set increment
WriteCommandToLCD(0x01); // Clear the screen
delay_ms(2); // Delay for cursor to return at zero position
void WriteStringToLCD( char *s)
while(*s)
WriteDataToLCD(*s++); // print first character on LCD
#include <stdio.h>
#include <lcd.h>
void InitLCD(void);
char k= 0x00;
void main()
ClearLCDScreen();
while(1)
//delay_ms(100);
ClearLCDScreen();
delay_ms(100);
WriteDataToLCD(k);
delay_ms(500);
// Define Pins
#byte LATB = 0x02CC
#byte ODCB = 0x02CE
unsigned char data;
//long long data;
int16 test;
//int8 addr = 0x33;
//int8 data = 0x22;
delay_us(500);
int temp =command;
temp=(temp<<8);
output_b(temp );
ToggleEpinOfLCD();
int temp =LCDChar;
temp=(temp<<8);
ToggleEpinOfLCD();
void InitLCD(void)
output_b(0x0000);
delay_ms(40);
delay_ms(6);
delay_us(300);
delay_ms(2);
while(*s)
