amihomo
Full Member level 5
- Joined
- Jan 9, 2007
- Messages
- 287
- Helped
- 66
- Reputation
- 132
- Reaction score
- 43
- Trophy points
- 1,318
- Location
- PERSIAN Gulf
- Activity points
- 3,115
ts1620a-20/y
Hi
I've written an LCD driver program in CodeVision, but I have not used any existing LCD library.
My LCD is a 16 by 2 character LCD module (TS1620A-20/Y from www.lcdstar.com ).
the code is full of illustrating comments.
the code was tested and works fine. but it is a simple tutorial and may not be usable for real world applications.
The distinctive feature of this code is that I have used the LCD busy flag instead of using delay functions ,so it will work regardless of LCD response time and needs no further customization of delay when the LCD is replaced.
currently I have written the code for the 4-bit interface mode of LCD , but i'm testing and debugging it. the code work well but i have problems with cursor positioning and I'll soon fix it.
Cool
cheers
Hi
Project : LCD 8-bit interface Test
Author : kouchenan(amihomo) ([url]www.amihomo.persianblog.ir[/url])
Chip type : ATmega8535
Clock frequency : 4.000000 MHz
PORTC[0..7] ==> DB0..DB7 LCD data bus (pin 14-pin7)
LCD EN (pin 6) ==> PORTD.7
LCD RW (pin 5) ==> PORTD.6
LCD RS (pin 4) ==> PORTD.5
#include <mega8535.h>
#include <string.h>
#include <delay.h>
#define EN PORTD.7
#define RW PORTD.6
#define RS PORTD.5
#define BF PINC.7 //busy flag
/* LCD Commands ( Refer to LCD Data Sheet ) */
/* Standard command should work with most common devices */
#define write_data 0x00 /* With RS = 1 */
#define clr_lcd 0x01 /* Clear Display */
#define ret_home 0x02 /* Cursor to Home position */
#define entry_mode 0x06 /* Normal entry mode */
#define entry_mode_sh 0x07 /* - with shift */
#define sys_set_4_bit 0x28 /* 4 bit data mode 2 line ( 5x7 font ) */
#define sys_set_8_bit 0x38 /* 8 bit data mode 2 line ( 5x7 font ) */
#define disp_on 0x0C /* Display ON */
#define disp_off 0x08 /* Cursor plus blink */
#define cursor_on 0x0E /* Switch Cursor ON */
#define cursor_on_blink 0x0F /* Switch Cursor ON ,Blink ON */
#define cursor_off 0x0C /* Switch Cursor OFF */
#define move_cursor_l 0x10 /* Move cursor one character left */
#define move_cursor_r 0x14 /* Move cursor one character right */
#define scrl_disp_l 0x18 /* Scroll display 1 character left (all lines)*/
#define scrl_disp_r 0x1E /* Scroll display 1 character left (all lines)*/
#define goto_line1 0x80 /* Line 1 position 1 */
#define goto_line2 0xC0 /* Line 2 position 1 */
void waitLCD(void);
void writeLCD(unsigned char byte ,unsigned char rs); //rs=0 for commands, rs=1 for data
void putStr(unsigned char str[]);
void initLCD(void);
void gotoXY(unsigned char x ,unsigned char y);
void main(void)
char msg[]="Hello World!This is an LCD test!";
DDRC=0xff;
PORTC=0xff; //Set all data pins to 1 initially
DDRD=0xff;
initLCD();
putStr(msg);
while (1)
//loop forever
void initLCD(void)
//delay_ms(45);
writeLCD(sys_set_8_bit,0);
writeLCD(cursor_on_blink,0);
writeLCD(clr_lcd,0);
writeLCD(entry_mode,0);
DDRC=0xff;
PORTC=byte;
RS=rs; //rs=0 for commands, rs=1 for data
RW=0;
EN=1;
EN=0;
waitLCD();
//monitor the busy flag of LCD on its DB7
void waitLCD(void)
unsigned char busy=1;
//unsigned char cnt=0;
do
DDRC=0xff;
DDRC=0x00; //configure all bits as inputs
EN=0; //Start LCD command
RS=0; //It's a command
RW=1; //It's a read command
EN=1;
busy=BF; //read the busy flag
//cnt++;
} while(busy==1);// && cnt<255);
EN=0; //Finish the command
RW=0; //Turn off RW for future commands
unsigned char i;
for (i=0;i<strlen(str);i++)
if (i>15)
gotoXY(1,i-16);
writeLCD(str[i],1);
//x is 0 or 1
//y is between 0 and 0x0f
unsigned char pos;
pos=x ? (0x80+0x40+y):(0x80+y) ;
DDRC=0xff;
PORTC=pos;
RS=0;
RW=0;
EN=1;
EN=0;
waitLCD();
Cool
cheers
