lbr for molex 100pin connector 51338-1074
giantorion
Eagle Lbr for Molex 100pin connector 51338-1074
Hello
I'm a new user from Eagle from Cadsoft
I search library for Molex 0,4mm 100pin connector, model 51338-1074 for the pcb side, where i can connect the Enabler III Oem modem. Have anyone this lbr?
Best regards
giantorion
Re: Eagle Lbr for Molex 100pin connector 51338-1074
I don't have it, but if you are a new user, the best way to practice to read the Help-file or the user manual, and draw it yourself. It is not a big work to draw a simple connector, meantime you practice the usage of Eagle. Win-win.
Anyway, if you start to use seriously the program, you will end up with your own library, then why not start with it immediately?
Hi, mpopovics
You are right. I will try myself
Best regards
giantorion
Hi giantorion,
Could you please tell me what does the lbr library look like?
Can you show me an example?
Thanks in advance.
B.R.
Hi jojo2520
Sure.
Link to the graphics of the Molex connector and for 216 pin IC in LQFP216-P-2424 case
Sorry, can't attach the Datasheet PDF, this Forum don't support it
Best regards
giantorion
You can attach PDFs, although if it is a readily available datasheet it is best to link to it on the manufacturers web site.
Keith.
