I'm a new user from Eagle from Cadsoft
I search library for Molex 0,4mm 100pin connector, model 51338-1074 for the pcb side, where i can connect the Enabler III Oem modem. Have anyone this lbr?
Re: Eagle Lbr for Molex 100pin connector 51338-1074
I don't have it, but if you are a new user, the best way to practice to read the Help-file or the user manual, and draw it yourself. It is not a big work to draw a simple connector, meantime you practice the usage of Eagle. Win-win.
Anyway, if you start to use seriously the program, you will end up with your own library, then why not start with it immediately?
Hi jojo2520
Sure.
Link to the graphics of the Molex connector and for 216 pin IC in LQFP216-P-2424 case
Sorry, can't attach the Datasheet PDF, this Forum don't support it
