Re: layout question
See for every condition we have some trade off. what will happen if you do more number of fingers, The source and draing cap will become more. If we increase the drain cap un-necessiarly it will make much load on output net.
So we should think about area constraint and source drain cap and fingering too.
In general we prefer to put less than 10um of the width for each transistor.
For example you have 20/2 transistor and better you can make it as 5/2 m=4 or 4/2 m=5.
If you put 10/2 you are not going to reduce more gate resistance, and if you some 1/2 m=20 or 2/2 m=10, then you are going to increase the source drain cap.
So you can decide 5/2 m=4 or 4/2 m=5, according to your layout floor plan. Guess understood. Correct me if I am wrong anywhere. Thank You.
