I am working on 12-bit SAR ADC design, in which i make use of capacitor array to build DAC block. All simulations work fine in schematic simulations. However, when I did a post layout simulation on DAC block, the result is very bad. In the DAC block, I need a few switches to control the capacitor DAC. When I connect the switch to capacitor array in the layout, the result is very bad; however, when I test
the capacitor alone, it works well. Can any one tell me the problem? The capacitor I use is cploy 1pF; the switch I use is nMos, 0.4x0.35 (minimum size); I use AMS 0.35 process.
