laser diode problem the beam width using the knife edge
harryd
Member level 1
laser diode problem
i need to find out the beam width using the knife edge technique , so i need find out what type of detector should be used in the experiment and why ?
laser diode problem
Your detector must have sensitivity at the desired wavelength & speed for the pulsing, than applicable packaging...
K.
Re: laser diode problem
would a simple photo diode do the trick ?
laser diode problem
Whats your wavelength and power pls?
well i am using a simple laser point so thats about 630 nm and 2mw i think . anyways, i think i will just use a simple photodiode.
Or you can take in these case a simple Photoresistor too...
I think is the indication some easyer :)
K.
    harryd
ok i am using a transistor, i need a circuit for the transistor to detect the a red light from a laser pointer. i also need to know how to calculate the resistance required for the circuit etc...
thanks in advance
