luka_friend
Newbie level 2
- Joined
- Jan 16, 2015
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 38
Hi everyone!
I don't have a lot of electrical knowledge, so I will try to explain my problem the best as I can.
I have a MITSUBISHI/658nm-660nm 300-400mw CW Red Laser Diode, and 5.1V 0.7mA power source (used for charging mobile phones).
My 1st question is:
-if one pin on laser diode is positive and one pin negative power, what is the third pin?
And my 2nd question is (also my problem):
-I have wired a few resistors to drop the voltage of power source to 2.2V (which is specified for laser diode). When I plugged the laser diode to power source, I could see a little red dot, but not even close for what I need for laser cutting. So what am I doing wrong (I have seen tutorials on web using the same laser, so I think laser is not the problem).
-Should I connect both laser diode pins to + and the third pin to -?
-Should I use diffrent power source (some kind of switching power supply)?
Laser diode is from ebay: **broken link removed**
Laser diode would be used for cutting paper.
Thanks.
My 1st question is:
Thanks.
