Microwave123
Member level 2
I have been working on a Lange coupler with MWO, Ansoft Designer and HFSS. What I do is I start my initial design with MWO or Designer, then I use HFSS to verify my results. However, the results from HFSS is very different from Designer and MWO.
I understand that HFSS should give me the most accurate results since it is a 3D simulator. However, I expect reasonable accuracy from MWO and Designer too. In this case, it is not.
I am not sure if the built in bond wire model in HFSS is accurate as well. Also, the boundary condition I am using is a radiation boundary. Does this sound right? I am using this type of boundary condition because I have seen this set up in a tutorial before. I am not sure if this is correct.
Has anyone use MWO and/or HFSS for designing a Lange coupler? If so, were the simulation results very different?
Thank you in advance!
