KLV32S400A - White Screen Display
franticguy_82
Newbie level 2
Newbie level 2
Hi Team,
I was watching TV yesterday and suddenly the screen turned white. No clue what happened. Contacted the service center and they said panel will be changed.
Sound and other display features are intact e.g. Menu keys and volume display are appearing on the screen.
When I connected my laptop through HDMI cable, the display is perfect. But, on the other hand, when I connected the DVD player, the white display was all over again :-(
Please help as what can be the issue here.
it was not a panel fault
Thanks Pradeep...what can be the issue here. Can it be a port issue, since both my cable tv connection and the dvd player are connected thru the cable (white+red+yellow). Laptop connection is done directly through the HDMI cable.
First of all you should check all the 0ohm resister or fuses used in vcc rails.
Hi Team,
