mtkee2003
Full Member level 2
hi
i want to implement a keypad using PicBasic PRO, and i want to use the interrupt on change of PORTB. i am using 16F877 and i can't use "polling routine" in this project with , also i can't use any Keypad IC (like 74C922).
i wrote a program and i attach its PROTEUS file its schematic.
thanks in advance,
with best regards.
'* Name : PORTB_CHANGE.BAS *
'* Author : Mostafa Taghavi Kani *
'* Notice : Copyright (c) 2006 Embedded Technology *
'* : All Rights Reserved *
'* Date : 2006/12/14 *
'* Version : 1.0 *
'* Notes : *
'include "modedefs.bas"
define OSC 4
DEFINE LCD_DREG PORTA
DEFINE LCD_DBIT 0
DEFINE LCD_RSREG PORTA
DEFINE LCD_RSBIT 4
DEFINE LCD_EREG PORTE
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
GIE VAR INTCON.7
PEIE VAR INTCON.6
T0IE VAR INTCON.5
INTE VAR INTCON.4
RBIE VAR INTCON.3
T0IF VAR INTCON.2
INTF VAR INTCON.1
RBIF VAR INTCON.0
RBPU VAR OPTION_REG.7
INTEDG VAR OPTION_REG.6
T0CS VAR OPTION_REG.5
T0SE VAR OPTION_REG.7
PSA VAR OPTION_REG.3
PS2 VAR OPTION_REG.2
PS1 VAR OPTION_REG.1
PS0 VAR OPTION_REG.0
i VAR BYTE
'PORTB VAR BYTE[3]
x VAR BYTE
ROW VAR BYTE
COL VAR BYTE
J VAR BYTE
R VAR BIT
C VAR BIT
TRISB=%11110000 : 'PORTB=%11111111
TRISD=%00000000
i=0
'OPTION_REG=%01010111 'ONLY FOR CAMPACTING THE PROGRAM
INTCON = %10001000
RBPU=0
ON INTERRUPT GOTO TEST
MAIN:
' PORTD=$FF
' PAUSE 200
' PORTD=$00
' PAUSE 500
IF I==0 THEN
LCDOUT $FE,1,"PRESS ANY KEY!"
ELSE
LCDOUT $FE,1,"(ROW,COLUMN)=","(",#R,",",#C,")"
ENDIF
PORTB=(PORTB & %11110010)
' PAUSE 20
PORTB=(PORTB & %11110100)
' PAUSE 20
PORTB=(PORTB & %11111000)
' PAUSE 20
' FOR J=1 TO 3
' PORTB=%00000001
' PORTB=PORTB << 1
' NEXT J
' WHILE(J)
' J
GOTO MAIN
DISABLE
TEST:
@ MOVF PORTB,W 'IMPORTANT:reads PORTB and moves the value to W register!!!
' @ MOVE?BA PORTB 'another ALTERNATE for above line!
ROW=(PORTB & %11110000)
COL=(PORTB & %00001110)
SELECT CASE ROW
CASE %00010000
R=1
CASE %00100000
R=2
CASE %01000000
R=3
CASE %10000000
R=4
END SELECT
' FOR K=1 TO 3
' IF COL.K=1
' NEXT K
SELECT CASE COL
CASE %00000010
C=1
CASE %00000100
C=2
CASE %00001000
C=3
END SELECT
i=i+1
' LCDOUT $FE,1,"PORTB CHANGES=",#I
RBIF=0
' PORTD=$00
RESUME
ENABLE
END
thanks in advance,
with best regards.
