#pragma language=extended
#include <df0034.h>
#include "keyboard.h"
#include "infhotel.h"
#include "rtc.h"
#include "lang.h"
#include "rs232.h"
uchar keyModifier; // E0, E1,
saddr uchar uniKey; // keystroke converted to pseudo-unicode format (signed 128bit)
saddr uchar lastUniKey; // Store previous key in pseudo-unicode format
bit keyReleased; // 1 if F0 keystroke received
saddr uchar kbdbytes; // number of bytes received from keyboard
saddr uchar kbdbuffer[KBDBUFFERLEN]; // keyboard buffer
uchar kbdbits; // number of received bits (start bit inclusive)
uchar kbdbyte; // receiving byte
uchar kbdto; // timeout for a keystroke receiving
bit kbdtx; // 1 when transmitting to keyboard, 0 when receiving
bit kbdbit; // received bit
bit kbdoddparity; // 1 if odd number of bits before parity
bit kbderr; // 1 if any errors
struct kbd_struct kbd_table;
// ì è + ò à ù
const uchar uni2ascii[UNI2ASCIILEN]= " abcdefghijklmnopqrstuvwxyz0123456789\\'\x8d\x8a+\x95\x85\x97>,.-.0123456789+-*/ ";
// é * ç ° §
const uchar shiftuni2ascii[UNI2ASCIILEN]=" ABCDEFGHIJKLMNOPQRSTUVWXYZ=!\"£$%&/()|?^\x82*\x87\xf8\xf5<;:_.0123456789+-*/ ";
// 0 4 8 C 0 4 8 C 0 4 8 C 0 4 8 C 0
// Map keystrokes to a map similar to unicode.
uchar const key2uni[132] = {
0x00, K_F9, 0x00, K_F5, K_F3, K_F1, K_F2, K_F12,
0x00, K_F10, K_F8, K_F6, K_F4, K_TAB, 0x25, 0x00,
//10
0x00, 0x00, 0x00, 0x00, 0x00, 0x11, 0x1c, 0x00,
0x00, 0x00, 0x1a, 0x13, 0x01, 0x17, 0x1d, 0x00,
//20
0x00, 0x03, 0x18, 0x04, 0x05, 0x1f, 0x1e, 0x00,
0x00, 0x40, 0x16, 0x06, 0x14, 0x12, 0x20, 0x00,
//30
0x00, 0x0e, 0x02, 0x08, 0x07, 0x19, 0x21, 0x00,
0x00, 0x00, 0x0d, 0x0a, 0x15, 0x22, 0x23, 0x00,
//40
0x00, 0x2e, 0x0b, 0x09, 0x0f, 0x1b, 0x24, 0x00,
0x00, 0x2f, 0x30, 0x0c, 0x2a, 0x10, 0x26, 0x00,
//50
0x00, 0x00, 0x2b, 0x00, 0x28, 0x27, 0x00, 0x00,
0x00, 0x00, K_ENTER, 0x29, 0x00, 0x2c, 0x00, 0x00,
//60
0x00, 0x2d, 0x00, 0x00, 0x00, 0x00, K_BACKSP, 0x00,
0x33, 0x1c, 0x00, 0x36, 0x39, 0x00, 0x00, 0x00,
//70
0x32, 0x31, 0x34, 0x37, 0x38, 0x3a, K_ESC, 0x00,
K_F11, 0x3c, 0x35, 0x3d, 0x3e, 0x3b, 0x00, 0x00,
//80
0x00, 0x00, 0x00, K_F7
void getKeyStroke(uchar *ch) {
// return the first keystroke in the kbdbuffer[]
uchar i;
if (kbdbytes) {
*ch=*kbdbuffer;
kbdbytes--;
for (i=0;i<kbdbytes;i++)
kbdbuffer[i]=kbdbuffer[i+1];
if (kbdbytes==KBDBUFFERLEN-1) {
kbdclk=1; // release kbdclk to reenable keyboard rx
kbdclkm=1;
#ifdef DEBUGKBD
rs232putbyte2hex((uchar) *ch,'\n');
#endif
return;
} else {
*ch=0;
return;
// when new char was received, reinitialize variable (used by kbdGetChar)
#define kbdNewChar() { keyModifier=0; keyReleased=0; }
/* Return in uniKey the character read from kbdbuffer, 0 if there are no chars available */
void kbdGetChar (void) {
uchar ch;
// at this point i will read:
// a. new complete or partial keystroke
// b. completion of previous received partial keystroke
// c. another part of previous received partial keystroke
if (uniKey)
lastUniKey=uniKey;
uniKey=0; // initialize uniKey to ZERO (useful if a "don't care key" was pressed/released)
while (1) {
getKeyStroke(&ch); // will store in ch the next part of keystroke
if (ch==0) {
// No keystrokes available
return;
if (ch==0xF0) {
keyReleased=1;
} else if (ch==0xE0) {
keyModifier=1;
} else if (ch==0xE1) {
keyModifier=2;
} else if (ch==0xAA) {
// must reinitialize keyboard
kbd_initialize(); // PowerOn: initialize keyboard and empty kbdbuffer[]
kbdbytes=0;
uniKey=0;
kbdNewChar(); // Initialize the variables used by this function (keyRelease, keyModifier, ...)
return;
} else if (ch<0x84) {
if (keyModifier==0) {
switch (ch) {
case 0x12: // LEFT SHIFT
case 0x59: // RIGHT SHIFT
kbd_table.shift=!keyReleased; break;
case 0x14: //LEFT CONTROL
kbd_table.ctrl=!keyReleased; break;
case 0x11: //LEFT ALT
kbd_table.alt=!keyReleased; break;
case 0x58: //CAPS LOCK
if (keyReleased==1) {
kbd_table.capsLock^=1;
kbd_initialize();
} break;
case 0x77: // NUM LOCK
kbd_table.numLock^=1; //Num lock always active!
kbd_initialize();
} break;
case 0x7E: // SCROLL LOCK
kbd_table.scrollLock^=1;
kbd_initialize();
} break;
case 0x07: // F12
if (lastUniKey!=K_F12 || keyReleased) {
uniKey=K_F12;
if (keyReleased)
uniKey|=0x80;
break;
default:
uniKey=key2uni[ch];
if (keyReleased) {
uniKey|=0x80;
kbdNewChar();
return;
} else if (keyModifier==1) {
switch (ch) {
case 0x14: //RIGHT CONTROL
kbd_table.ctrl=1^keyReleased; break;
case 0x11: //RIGHT ALT
kbd_table.alt=1^keyReleased; break;
case 0x4A: // KeyPad /
uniKey=0x25;break;
case 0x5A: // KeyPad ENTER
uniKey=K_ENTER;break;
case 0x6B: //K_LEFT
uniKey=K_LEFT; break;
case 0x74: //K_RIGHT
uniKey=K_RIGHT; break;
case 0x72: //K_DOWN
uniKey=K_DOWN; break;
case 0x75: //K_UP
uniKey=K_UP; break;
case 0x70: //K_INSERT
uniKey=K_INSERT; break;
case 0x71:
uniKey=K_DELETE; break;
case 0x6c:
uniKey=K_HOME; break;
case 0x69:
uniKey=K_END; break;
case 0x7d:
uniKey=K_PGUP; break;
case 0x7a:
uniKey=K_PGDOWN; break;
case 0x7c:
uniKey=K_SYSRQ;break;
if (keyReleased) {
uniKey|=0x80;
kbdNewChar();
return;
} else if (keyModifier==2) {
if (keyReleased==0) {
#ifdef DEBUGKBD
rs232putchar('E');
rs232putchar('1');
rs232putchar(' ');
rs232putbyte2hex(ch,' ');
#endif
return;
void kbd_sendData(uchar data) {
// prepare for the transmission of commands to keyboard, then wait
// until ISR finish transmissions, wait for the ack and retransmit the command
// if NOACK.
uchar i,j,ch;
for (i=5;i;i--) {
kbdtx=1; // tell interrupt routine to tx data
kbdbyte=data;
kbdbits=0;
kbdoddparity=0;
kbderr=0;
kbdto=20; // keyboard must complete operation within 15ms
kbdintmask=1;
kbdclk=0; // pull clock low
kbdclkm=0;
for (j=0;j<100;j++); // wait for 100uS
kbddata=0; // pull data low, then release clock
kbddatam=0;
for (j=0;j<10;j++);
kbdclk=1;
kbdclkm=1;
kbdintflag=0;
kbdintmask=0;
// ok, start bit was transmitted, then interrupt routine will do the rest
// wait until data will be TXed
for (j=100;j;j--) {
unconditionalmsleep(2);
if (kbdtx==0)
break;
kbdNewChar();
if (j==0) {
kbdtx=0;
kbddata=1; // keyboard not connected: set kbd_data as input, then exit
kbddatam=1;
return;
if (kbderr) {
#ifdef DEBUGKBD
rs232puts("kbd_sendData: Data TXed, but got NACK\n");
#endif
unconditionalmsleep(10); // data transmitted but not acknowledged
continue;
for (j=25;j;j--) {
// wait for ACK
while (getKeyStroke(&ch),ch) {
kbdNewChar();
if (ch==0xfa)
break;
if (ch==0xfa) {
return;
} else if (ch) {
#ifdef DEBUGKBD
rs232puts("kbd_sendData: got answer 0x");
rs232putbyte2hex(ch,'\n');
#endif
void kbd_initialize(void) {
// reset keyboard rate & leds accordingly to kbd_table structure
// Must be called after keyboard powerOn (when keyboard send 0xAA data)
unconditionalmsleep(20);
// Don't alter rate and delay... default is 10.9cps and 500ms
//kbd_sendData(KBD_CMD_SET_RATE);
//kbd_sendData(0x00); // maximum rate, minimum delay
kbd_sendData(KBD_CMD_SET_LEDS);
kbd_sendData(kbd_table.scrollLock|(kbd_table.numLock<<1)|(kbd_table.capsLock<<2));
kbdNewChar();
uniKey=0;
void kbdinit(void) {
kbdclk=1; // kbdclock=output
kbdclkm=1;
kbdclku=1;
kbddata=1;
kbddatam=1;
kbddatau=1;
kbdintegp=0;
kbdintegn=1;
kbdintflag=0;
kbdintmask=0;
kbdintprio=1;
kbdtx=0;
kbdbytes=0;
kbdbits=0;
kbdbyte=0;
kbdbit=0;
kbderr=0;
kbdoddparity=0;
kbdto=0;
kbd_table.capsLock=0;
kbd_table.scrollLock=0;
kbd_table.numLock=1;
kbd_table.shift=0;
kbd_table.alt=0;
kbd_table.ctrl=0;
// initialize keyboard only when 0xAA (PowerOn) will be received
// kbd_initialize();
static interrupt [INTP3_vect] void kbdinterrupt(void) {
// called everytime the kbdclk goes low => must latch kbddata
if (kbdto==0) { // Control keyboard timeout (2 ms to receive a keystroke
kbderr=0;
kbdbits=0;
kbdoddparity=0;
kbdto=3; // set keyboad time out
kbdtx=0;
kbddata=1;
kbddatam=1;
if (kbdtx) {
// transmit to keyboard
kbdbits++;
if (kbdbits<=8) {
if (kbdbyte&1) {
kbdoddparity^=1;
kbddata=1;
} else {
kbddata=0;
kbdbyte>>=1;
} else if (kbdbits==9) {
// transmit parity
kbddata=~kbdoddparity;
} else if (kbdbits==10) {
// transmit stop bit
kbddata=1;
kbddatam=1;
} else if (kbdbits==11) {
// get acknowledge
kbderr=kbddata;
kbdtx=0;
kbdto=0;
} else {
// receiving from keyboard
kbdbit=kbddata; // read data
if (kbdbits==0) {
if (kbdbit) {
// control start bit (must be ZERO!)
kbderr=1;
} else if (kbderr==0) {
if (kbdbits>=1 && kbdbits<=8) {
kbdbyte>>=1;
if (kbdbit) {
kbdbyte|=0x80;
kbdoddparity^=1;
// parity bit
if (kbdbit==kbdoddparity) {
kbderr=1;
// stop bit
if (kbdbit==0) {
kbderr=1;
if ((++kbdbits)==11) {
if (kbderr==0) {
// no errors => store received byte to kbdbuffer
kbdbuffer[kbdbytes]=kbdbyte;
if ((++kbdbytes)==KBDBUFFERLEN) {
kbdclk=0; // pulling kbddata low, keyboard communication will be inhibited
kbdclkm=0;
kbdtimeout=KBDTIMEOUT;
kbdto=0;
kbdintflag=0; // reset interrupt flag
uchar kbdAsciiConv(void) {
// read uniKey global variable: return 0 not ascii
if (uniKey&0x80 || uniKey==0)
return 0; // key released or unknown
uniKey&=0x7f;
if (uniKey<=26) {
if (kbd_table.shift^kbd_table.capsLock) {
return shiftuni2ascii[uniKey];
} else {
return uni2ascii[uniKey];
} else if (uniKey<=0x30) {
if (kbd_table.shift) {
} else {
} else if (uniKey<UNI2ASCIILEN) {
return 0;
