keyboard and LCD interfacing with 89C51 microcontroller
gang_engnr
Newbie level 1
Re: keyboard interfacing
hi, my project is about the keyboard and lcd interfacing. i have to display the message on lcd written by the keyboard on run time using 89C51 microcontroller for the lcd interface.
i have already written the lcd routine, have configured the UART of the processor but dont know what to do next....... can anyone help me with it??
Added after 4 minutes:
em using the serial port of my pc for transmission.
If I understand your task correctly, you intend to write on a PC keyboard, transmit data via serial port to 89C51 and display it in real time on an LCD ..
If that’s the case, start with Hyperterminal at the PC side and short serial port interrupt subroutine at the 8051 end, read ASCII characters that are transmitted by the PC, convert them from ASCII to whatever LCD can accept and send them to the LCD ..
Rgds,
IanP
What kind of keyboard is it? Is this a 4x4 keypad also interfaced to the MCU?
If you post a diagram or schematic of what you are trying to achieve, you will receive more replies.
Also, how do you write code, C or assembly?
If you use PS2 keyboard,it is unnessary to do it via a computer and RS-232.There are many methods which guide you how to interface a PS2 keyboard with a MCU.
use this link for tutorial on
and use this one for
