yes, i ment the BIST. To run the BIST you have to load a bitfile to your FPGA, right?
That means there is most probably a LCD controller written in Verilog or VHDL that takes the control part. I expect your software to communicate with that controller, and the controller with the LCD...
Chances are very high that you have access to that code.
again, just hints you'll have to look on this for yourself
that BIST has A LOT of stuff that does not matter in your case - if you find yourself confused it'll be better to start from scratch.
do you know the manufacturer of your LCD? and the name of the part? you can find references to all components on your evaluation board on the user guide of your board
i found a bunch of useful links on google
sorry, seems like it uses the GPIO module to connect with the LCD. the driver is written in c code. I guess i pointed you in the wrong direction.
