People come up with peculiar or funny answers in interviews or exams:
Interviewer: Why is a thicker conductor necessary to carry a current in A.C. as
compared to D.C. ?
Candidate: An AC current goes up and down (drawing a sinusoid) and requires more space inside the wire, so the wire has to be thicker.
Interviewer: How will you tell if that wall outlet carries AC or DC ?
Candidate: I will put my finger in. If it is pushed away, it is DC. If it gets stuck, it
was AC.
Interviewer: How will you reverse direction of an induction motor?
Candidate: I will remove the four bolts at the base, turn the motor around, and put back the bolts.
Interviewer: How do you start a synchronous motor?
Candidate: Vrrrrrrrmmmmmmmmmmmmmmmmmmm (in rising pitch)
Interviewer: Stop! Stop!
Candidate: rrrrrrrmmmmmmmmmmmmmmmmmmmm (in falling pitch)
Interviewer: How do you limit surge current within an integrated circuit?
Candidate: By using a miniature circuit breaker.
External (to student) : " Why does a capacitor block DC but allow AC to pass through?
Student: See, a capacitor is like this ---| |--- , OK. DC Comes straight, like this ----------, and the capacitor stops it. But AC,goes UP, DOWN, Up DOWN and jumps right over the capacitor!"
Examiner : "What is a step-up transformer?"
Student : "A transformer that is put on top of electric poles."
Examiner (smiling): "And then what is a step-down transformer?"
Student (hesitantly):"Uh - A transfomer that is put in the basement or in a pit?"
Examiner (pouncing): "Then what do you call a transformer that is installed on the ground?"
(student knows he is caught -- can't answer)
Examiner (impatiently): "Well?"
Student (triumphantly): "A stepless transformer, sir!"
If we think a motor like one Iman free (for rotation) in center and two other imans, just at circular border, that change the position of North/South poles in relation to Central Iman, to get motion. We can see what forces are necessary to reverse motion.
