ggnadkarni
Junior Member level 2
A single wire method....
Subject: Fw: A single wire non Tesla electrical energy transmission technique
An Ungrounded floating electrical point ( totem pole) is connected to a resistor and the other end of the resistor is connected to a floating straight conductor 500 miles long.This is the kind of length used in power transmission.
The time to travel to the end of this conductor and back is roughly 5 milliseconds from resistor end.
The floating electrical point is switching from high voltage to low at the rate 200 Hz with 50% duty cycle,which is inverse of five milliseconds.
My theory is in-spite of everything being floating,there will be consumption of power by the resistor.
Since no ground is used,there will be no shock hazards.So,no transmission towers,transformers or insulators.
Eventually,the 500 mile long transmission line will be a module in each home like a bulk acoustic delay line.
There will be only one single line of the size of a glass fibre getting into the house from outside.
A suboceanic bare single wire can be used to transmit power between continents.No need to import coal from far and wide places.
